Implementing Hitag2 encryption on PKE base station.
vivek_sri
I'm working on PKE project with S32K144 as base station and Token+ tag.
I'm looking for any reference manual or sample code to implement the Hitag2 encryption and transmit the following data and verify the response.
Wake Up ID IDE (4 bytes) Data Command: 0x00 (1 byte) + Random No (4 byte) + Signature (2 byte) + CRC (1 byte)
Thanks & regards,
Vivek Srivastava
Tags (3)
Kan_Li
Hi @vivek_sri ,
What do you mean with the Hitag2 encryption? Is it some kind of encryption performed on the data to be stored in Hitag2? I think you may use the module of Cryptographic Services Engine (CSEc) to implement such as AES128 encryption.
Kan
vivek_sri
Hi @Kan_Li
Actually I'm using NXP evaluation board to implement PKE system which comes with S32K board as base station and NCF29A1 Token+ module as Keyfob.
The keyfob is pre flashed with a demo code which supports Hitag 2 encryption method (like Hitag 3 and AES).
The authentication process is as follows:
PKE authentication: Challenge + signature are received via LF interface, processed by the HITAG-2 algorithm, verified for correctness and response is transmitted via RF interface.
Command (LF):
Response (RF): Data Response (6 byte) + CRC (1 byte)
I want to implement the Hitag 2 algorithm in my base station to verify the response.
Vivek Srivastava
Kan_Li
Hi @vivek_sri ,
Which NXP evaluation board are you using to implement PKE system? Is it OM6716 (https://www.nxp.com/products/security-and-authentication/secure-car-access/transponder-evaluation-an... )?
Kan
