If 2M CANFD is configured, what change should be made to PE Clock?
jingfang
I change data phase to 2M and change PE to Peripheral clock, change clockman->SCS CLK and SPLL.
Is there any other to change or explain's documentation?
Senlent
Hi@jingfang
If you are using the S32K1 series MCU, there is no problem with this configuration.
for example:
BR!
Senlent
Hi@jingfang
for example:
BR!
lama
Could you please add S32Kxxxx part number?
Ladislav
