INVSTATE fault with T32 09/2021
phuong_nguyenle
I'm encountering the issue with Trace32 when using it for S32K344 debug.
INVSTATE fault happen at the first line of code (Reset handler). This doesn't happen with T32 09/2020
Can you give me some hint for reason and fix this issue?
phuong_nguyenle
Thanks for your response!
This issue seems from my software but I don't know why.
You can see R14 (LR) is 0xFFFFFFFF (very strange) after system.resettarget.
Can you help me to give some reason for this?
rweiss
Contributor V
Hi Phuong,
I think it would be best if you contact Lauterbach support support@lauterbach.com for further assistance.
Reinhard
rweiss
Contributor V
Hi Phuong,
with which TRACE32 software version are you encountering this issue?
Reinhard
lukaszadrapa
Hello @rweiss ,
would you please find some time to help with this? Currently I have this version of T32 and I can't see such issue:
Lukas
