IAR Debug Driver for S32K142 Eval Board
sean_dvorscak
I am trying to figure out what debug driver to use for the S32K142 evaluation board.  I am using the USB cable, and none of the options I have worked.
What driver am I supposed to use?
Robin_Shen
Hi sean_dvorscak,
Then on board debugger of S32K142EVB is OpenSDA(PE micro). So if you want to use this on board debugger, please select OpenSDA. I am able to use  OpenSDA debug the hello_world_iar project in SDK.(C:\NXP\S32DS_ARM_v2.2\S32DS\software\S32SDK_S32K1xx_RTM_3.0.0\examples\S32K142\demo_apps\hello_world_iar)
Please check if the driver for OpenSDA is installed in Device Manager.
Robin
