I2C driver related issue
527件の閲覧回数
pranavshinde
I am using S32K144 controller for my project.
While using I2C driver in non-blocking mode, I am facing an issue.
My application requires reading the data in chunks of 12 bytes from I2C peripheral.
If I read 12 bytes of data from I2C peripheral then everything is working fine but if I attempt
to read 24 bytes of data, I am not able to read it.
What could be the reason for this?
516件の閲覧回数
danielmartynek
Which driver do you use SDK or MCAL, LPI2C, FlexIO? And which version?
If I understand, it works in the blocking mode, right?
Have you tried using DMA instead of interrupts?
Can you scope the bus?
If possible, please share the project.
Thank you,
BR, Daniel
