I can't download following two packages about S32K142-MC24.
It inferred that the package doesn't exist or removed to other places, but it didn't supply new address.
Where can I get these packages?
Waiting for your reply, thank you very much!
Sarah
Solved! Go to Solution.
You can download those files on the MCSXTE2BK webpage.
https://www.nxp.com/design/development-boards/automotive-motor-control-solutions/arm-based-solutions...
We will remove these files from our system to avoid confusion.
Thank you.
Thank you.
Thank you very much for the new link, I found the information I needed.
Sarah
You can use following way to download it. It looks like the search engine is directing to wrong (old) link.
You can find the correct access here, just scroll down the screen:
Or directly:
https://www.nxp.com/downloads/en/application-software/MCSXTE2BK142_SW.exe
Ladislav
I have informed responsible department.
They will fix it ASAP but I am sorry we have also to consider time zone where the guys are located.
Ladislav
