I am working on functional safety application for clock monitoring for S32K146 and I have 2 query
1. I have configured the SPLL and SOSC. As per my application, I am resetting the device incase SPLL and SOSC loss the clock happens.
SCG_SOSCCSR[SOSCCM] - System OSC Clock Monitor: I have enabled it
SCG_SOSCCSR[SOSCCMRE] - System OSC Clock Monitor Reset Enable : I have enabled it
SCG_SPLLCSR[SPLLCM] - System PLL Clock Monitor : I have enabled it
SCG_SPLLCSR[SPLLCMRE] - System PLL Clock Monitor Reset : I have enabled it
RCM_SRIE[LOL] - Loss of Lock Interrupt: I have enabled it
RCM_SRIE[LOC] - Loss of Clock Interrupt: I have enabled it
now how to inject the fault in clock (SOSC/SPLL) so that I can verify reset due to missing the clock?
2. as per the safety manual S32K1XXSM_Rev5.pdf section SM_213 Implementation hint, it is described that we can verify PLL output.
now my thinking is, if we are using below setting in EBTresos for clock configuration
then additionally SM_213 implementation hint is not required. is my understanding correct ?
looking your feedback soon...
