How to use the configuration tools for s32k342?
1,476 次查看
Jennie_Jing
I want to do something like below but using the mcu of s32k342:
HOWTO: Create a simple blinking LED project using ... - NXP Community
but there's no SDKs for s32k342. Also the RTD doesn't support k342.
so  how can I get a .mex file for k342 for generating code?
Thanks.
1,464 次查看
Senlent
Hi@Jennie_Jing
Version 2.0.0 Code Drop 01 release for the S32K342
BR!
     Jim,
5 回复数
1,465 次查看
Senlent
Hi@Jennie_Jing
BR!
     Jim,
1,452 次查看
Jennie_Jing
HI,Senlent,
     Thank you very much for your advice. After installed this RTK , then I new a project using S32DS.3.4 IDE, but the sdks cannot find by the IDE.
     Is this problem about the version of IDE or the GCC toolchain?
1,446 次查看
Senlent
Hi@Jennie_Jing
I haven't installed and used this package yet, you can look at the release documentation,it looks like you need to upgrade your IDE.
BR!
      Jim,
1,178 次查看
Ganesh_Pawar
Hi @Senlent,
    Greetings for the day ..!!!
        I am trying to get the Software develpoment kit for the S32K342 controller and i got to know about this community post regarding the SW32K3_RTD_4.4_2.0.0_D2203.exe and i installed but failed due to unavailabilty of EB tressos installation ,why is EB tressos studio required and what is its significance and guide me how do i proceed .
Thanks and regards,
Ganesh Pawar
1,440 次查看
Jennie_Jing
The issue has been resolved, because the RTD is not installed well ,and and the IDE must be restarted after installed.  Thank you a lot for your help to a beginner.
