How to use Idle Line Flag in LPUART ?
s32k146_ige
I am looking for this feature as explained in data sheet
IDLE is set when the LPUART receive line becomes idle for a full character time after a period of activity.
i would like to receive interrupt if RX is idle for particular char time, i didnt get any example related to this.
is there a way i can get this working ?
Tags (2)
Robin_Shen
Please check if you have received the non-SDK example.
Robin_Shen
If you are using S32K1 SDK, please refer to the discussion in S32K144 LPUART IDLE Line Interrupt Configuration
hope it helps.
Robin
s32k146_ige
I am not able to understand the link that you have shared.
do i need to enable DMA for idle state ? no we are not using SDK
But if there is proper example than we can make the same changed in our sdk
Robin_Shen
s32k146_ige
Yes, i have got, thanks for this, i will check with this and let you know if any further assistance is required
