How to use ECC to achieve the security requirements of flash and ram memory?
1,295 次查看
xiaohuang
I am using S32K118,How to use ECC to achieve the security requirements of flash and ram memory? Do you have sample code?
2 回复数
1,288 次查看
Senlent
Hi@xiaohuang
you can take a look at the documents AN12522:S32K1xx ECC Error Handing-Application Note.
and I send your a private message,please check/
link:
https://www.nxp.com/search?keyword=AN12522&start=0
BR!
     Jim,
标记 (1)
1,277 次查看
xiaohuang
ok got it, thanks a lot
