Hi, i want to set the pin to pullup state,but i can find configuration UI in PIN_MUX.
So where can i config the pin's pullup state?
Solved! Go to Solution.
This is a bug, the Functional properties window is for interrupts, pull setting.
It should be fixed in the next release/update.
In addition, when i open the "functional properity" page in pinmux, the "functional properity" page is empty. I'm not very sure whether it's ok or not.
