How to obtain the status of the SPI transmission channel?
Vernon
How can I obtain the status of the SPI transmission channel?
The RTD used is 'S32K3 RTD AUTOSAR R21-11 Version 3.0.0'.
Senlent
Hi@Venon
After installing RTD you can find some demos about SPI.
I give you some clue:
Vernon
Hi,@Senlent
Thank you for your help.
I want to know is there any other way?
If the Master is in MCU and Slave is on other platforms, can I only determine the channel status of the Master?  The reality is that when I use this function, the state I judge is always idle.
Senlent
Hi@Vernon
I can't think of a better way
