How to implement Wakeup via WUP in TCAN1463-Q1
ManuSharma
I'm currently working with Network Management topic and aiming to enable Pattern-based wakeup (WUP) for TCAN1463-Q1 for my project's Electronic Control Unit (ECU). Although I've reviewed the datasheet, I find myself with some unresolved questions. Could you provide clarification on the following points?
  1. Is WUP automatically enabled in TCAN1463-Q1, or is there a specific configuration needed?
  2. If WUP isn't enabled by default, what steps should I take to enable it for a particular message? Currently, my ECU is waking up for all received messages.
  3. Once I've implemented/enabled WUP for a specific message, what would be the best approach for testing it?
I appreciate any assistance you can provide on these matters.
Manu Sharma
PetrS
it would be better to ask TCAN1463-Q1 manufacturer for its functionality.
BR, Petr
