How to disable JTAG pin function on S32K324 chip
2,056件の閲覧回数
DamonH
Is there any way to disable JTAG/SWD port on S32K3xx chip?
In S32K1xx I can disable JTAG/SWD by set FSEC[SEC].
Is there similar function on S32K3xx?
Thank you.
Best Regards
Damon
タグ(2)
3 返答(返信)
2,018件の閲覧回数
petervlna
You can use life cycle for such purpose.
Yes, it is possible to restrict debug access via password protection when HSE is not installed.
Your need to program field CUST_DB_PSWD_A in UTEST memory with the desired password and then advance the lifecycle.
Peter
1,833件の閲覧回数
WXM
How do you advance the lifecycle?
2,050件の閲覧回数
snaku_lee
I think Device Configuration Format (DCF) records is a solution, but maybe there is another better way.
