How to detect ROM failure for S32K146
pratheek_b
How to detect below mentioned ROM Failures,
  • ECC Flash indicates 2-bit error
  • Flash checksum fault twice in a row (slow background task checking application 2 faults in row)
Tags (3)
lukaszadrapa
take a look at this application note:
https://www.nxp.com/docs/en/application-note/AN12522.pdf
Section "3.2 ECC for non-correctable errors" is the most interesting for you.
Lukas
