How to convert the allegro cadence designed schematic to Altium designed?
2,106 次查看
wanglipeng
Hello,I have a question about S32K344 Resource,the schematic about S32K344 is designed by allegro cadence, and I am going to convert these to Altium, but I don't find the .brd file, only have .dra and .olb file. Thanks for your help.
2,072 次查看
wanglipeng
Thanks for your help, but I don't have allegro software, I only have altium designer, Can anybody help me to convert these . olb files to  ASCII files(these could be imported by altium designer ) ?
2,095 次查看
petervlna
That is correct. You are referring to footprint files.
brd. is for whole board schematic. If you want board file, then select some EVB for S32K344 and on its web page there will be design files for the board including brd.
Peter
777 次查看
Rohan03
How can I convert footprint file of S32K41 (.dra) to Altium designer compatible format?
I have successfully converted schematic symbol file (.olb) to Altium library package file But for footprint Altium importer has .brd or .alg file format.
