Is there a way to use an external crystal as an clock to the a S32K116 controller to generate a clock frequency 32MHz? If yes, could you please provide some pointers on how to, and also what configs needs to be set?
Also can PLL be used for S32K116? From what I could see PLL is not added as part of S32K116 controller, from what I could see it is not.
