How to configure ECU Bus(0.2.22) for Unified bootloader Demo
564 次查看
vincent841
I'm trying to port 'unitified bootloader demo' on S32K144W reference board. (https://community.nxp.com/t5/S32K-Knowledge-Base/Unified-bootloader-Demo/ta-p/1423099) And I'm done to port bootloader demo into my board.
But I have no idea how to configure ECU Bus application to update the firmware. I'm newbie to this chipset & CAN communication. I attach some screen shots of application settings.
Please let me know how to configure in ECU bus. And also, please let me know how i can update new firmware using this tool. Thanks in advance.
标记 (1)
495 次查看
vincent841
I'm done to port and test this bootloader successfully on S32K144W reference board.
For your reference, the successful CAN settings is the following:
And then you can just select Address and click 'start' button.
I hope it will be helpful.
496 次查看
vincent841
500 次查看
PetrS
I’m sorry to say that Unified bootloader shared on the community is a demo only provided AS IS with no guarantees and no support. Currently we do not have resources to support this demo. We apologize for any inconvenience.
BR, Petr
