How to compile S32K3 HSE FW in project
已解决
跳至解决方案
1,554 次查看
ZhaozhangChen
I can see the description as shown in the picture in an744810-HSE FW install for S32K3xx (1.0).pdf, but I can't find the relevant setting file in democode. Which path is the file under and what is the file name?How to compile S32K3 HSE FW in project?
1 解答
1,535 次查看
danielmartynek
Hi @ZhaozhangChen,
Please use a support ticket instead of the public community as all the HSE documentation is under an NDA.
Anyway, you can find the answer to your question in the ReadMe.pdf of the demo, Section 4.1. HSE Firmware .
在原帖中查看解决方案
1 回复
1,536 次查看
danielmartynek
Hi @ZhaozhangChen,
