How to Flash Custom Board with S32K144 EVB
Dileep1441
We are having S32k144 Custom Board and We want to flash with S32K144 EVB,
Is there any possibility or process to flash the custom board with S32K144 EVB? If it is there please share with us and do the needful.
Also please share the Suggested Programming tool for flashing s32k144 Custom Boards.
Thanks in Advance.
lukaszadrapa
in-built OpenSDA interface on the EVB board is not supposed to be used for other boards.
For debugging purposes, it is possible to use probes from Pemicro or Segger. These are compatible with S32DS.
https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320180&productTab=1
https://www.segger.com/products/debug-probes/j-link/
The Multilink devices are available also directly on our website:
https://www.nxp.com/products/power-management/motor-and-solenoid-drivers/powertrain-and-engine-contr...
https://www.nxp.com/design/software/development-software/s32-design-studio-ide/universal-multilink-f...
If you are looking for a standalone production tool, there are options like:
https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320169&productTab=1
Lukas
Dileep1441
Hi Lukas,
Thanks for your Reply,
Could you please check this link once https://community.nxp.com/t5/S32K/Eval-board-as-debugger/td-p/766915
Here @jiri_kral telling it is possible with some changes,
I'm trying to Flash the Custom Board(S32K144) with Evaluation Board (FRDM board S32K144) over the J14 Connector.
Could you please share the Pin to Pin Connection Details at J14 Connector and Hardware Changes(if any) also Programming Process for Custom Board.
Thanks in Advance.
lukaszadrapa
Well, if you cut SWD_DIO from the MCU, it should work. But as I said, this is not expected use case.
Lukas
