Hello
I'm configuring the environment for s32k312, but I'm unable to receive CAN messages. Please assist me in resolving this issue
1.I don't see any problems with your configuration.
2.If you use the demo from the IDE,it's works in loop-back mode. If you want it to work in Normal mode, please configure the FlexCAN related pins.
3.Check whether your CAN transceiver needs to be configured.For example, if you are using S32K312EVB, then you need to configure the TJA1153 transceiver.
4.We have Non-Autosar(low-level driver) demo for reference
5.Please do not create topics repeatedly and abide by the rules of the community.
We're overloaded recently, thanks for your understanding.
