Hi, Can someone explain how to configure and use FlexIO as SPI in S32K148?
ravihhk2
I'm trying to configure the FlexIO as SPI for the first time, can someone give me some reference how to configure?
dianabatrlova
Hi Ravindra,
At first, I would like to recommend the doc AN12174 Using FlexIO to emulate communications and timing peripherals
https://www.nxp.com/docs/en/application-note/AN12174.pdf
and SW which you can use as reference:
https://www.nxp.com/webapp/Download?colCode=AN12174SW
Also, flexio_spi_s32k148 example is available in the S32 Design Studio for ARM version 2.2
I hope it helps.
Diana
dianabatrlova
Hi Ravindra,
I hope it helps.
Diana
ravihhk2
Thanks dianabatrlova for taking time to respond, This will help help me a lot :smileyhappy: :smileyhappy:@
