Hard fault occured when I read from S32K144 flash address 0x78400
中当陈
Product:S32K144 EVB
IDE:IAR for ARM 7.60.2
①:Where the hart fault occurred。The variable flashAddress=0x78400
②:Based on CFSR and HFSR,I found that MCU accessed a invalid address。
③:Then I watched memory range 0x78400--0x7840f,  the result was "-- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --"。So it indicated that the memory is not accessible。
Can someone tell me why the memory is not  accessible please?
Best regards!
danielmartynek
Please check FERSTAT[DFDIF] flag for Double-bit ECC errors.
中当陈
Hi, Daniel
Thank you for your prompt  reply!
After I erased all the flash, the problem disappeared.So, I check the FERSTAT[DFDIF] flag, the flash is 0.
Best regards to you!
