Hi All,
I am working on software update utility on S32K148 chip. To know whether the SW was flashed correctly or not, a dump of entire 2 MB of codeflash will be helpful.
Can you please help in knowing if there is any such utility in S32K design studio for the same?
Guru
Hello Guru,
Memory dump can be performed in the S32 Design Studio in the Memory view. Also, you can export memory into the file by export button see image below:
A similar question has been discussed in these community threads:
Exporting Array/Memory data from S32DS to Host system ?
S32DS how to properly dump RAM in debug session?
I hope it helps.
Diana
