There 's a puzzle when I debug a bootloader program。the Reset ISR is the default ISR that provided by S32DS named Reset_Handler and the VTOR is 0。
I found that:
the address in map fle is 0x00000400, which is the excepted.
the address in flash(in s32ds memory view) is 0x00000401
Then i investigated other funtions, the states puzzled me.
the address in map(Addr_m) is aligned to 4, but the address in flash(Addr_f) is not
addr_f = addr_m + 1
looking for help!
Best Regards!
Solved! Go to Solution.
sorry,i found the reason
