I have a project using LPIT module (LPIT_DRV_SetTimerPeriodByCount , LPIT_DRV_StartTimerChannels and LPIT_DRV_GetInterruptFlagTimerChannels), it runs well. Then I import FreeRTOS into my project (with default configuration), build and run it again, and I can not get the LPIT's flag interrupt. How can I fix it? Can LPIT's flag interrupt not get because RTOS tick interrupt?
do you mean that the interrupt flag is not set ever or it is set and just the interrupt is not triggered?
Lukas
