在按照S32K144EVB快速入门学习调试S32K144EVB时,按操作进行到第4.2步FreeMASTER JumpStart项目下载时,按操作接好设备,选好端口后在explore the board进行恩智浦半导体下载FreeMASTER JumpStart项目失败,报错为无法从链接打开项目文件'http://www.nxp.com/assets/downloads/data/en/application-software/s32K144EVB_OOBE.pmpx"
Hi taotao,
Please download the S32K144_EVB_JumpStart_PC and S32K144_EVB_JumpStart_Firmware.
If you don't want to flash program by using S32 Design Studio ARM2.0 IDE, you can copy and paste the S32K144_EVB_JumpStart_Firmware.srec file to the EVB-S32K144 drive.
Then you should be able to connect the board at 115200 baud rate.
Robin
