Fls Driver Compatibility
1,063 次查看
sathyaganesr
platform: S32k344
I wanted to know if the AUTOSAR Fls driver provided for the above platform is compatible with the external flash (S25FL512S).
Datasheet : https://www.infineon.com/dgdl/Infineon-S25FL512S_512_Mb_(64_MB)_3.0_V_SPI_Flash_Memory-DataSheet-v19...
Sathya
1,050 次查看
davidtosenovjan
FLS driver is generic enough in order to work with different external flash. The most important thing in order to work is the configuration of the driver, the configuration must match the needs of that specific external Flash.
In the RTD_FLS_UM.pdf section 3.2.3.3, you may see list of memories being tested with Fls driver.
