FlexCAN receive and send data using S32K3X4EVB T-172
990 次查看
kolyanimohanto
hello!
I have several doubts regarding CAN implementation for S32K3X4EVB T-172 board on S32DS v3.4
1) I tried running the FlexCAN_Ip_Example_S32K344. Can you please let me know whether PEMicro debugger can be used or not?? If not, then which debugger shall be used here??
Also, How to see if data is getting transmitted or received?? is there any other software that needs to be used to see the output?
2) I have checked out this link but how and where to see its output??? Example S32K344 FlexCAN_Ip TX/RX/EnhanceRXFIFO test S32DS3.4 RTD200 - NXP Community   Is 1 NXP board enough for the communication of this example?
1 回复
967 次查看
Julián_AragónM
Hi @kolyanimohanto,
I have answered your other community post instead (CAN communication using S32K3X4EVB T-172 Board - NXP Community).
Julián
