Failed to run generator "Wdg_TS_T40D2M10I4R0_GeneratorId" (mode: "verify") in EB Tresos Studio
1,567 次查看
ronakpatel84
Please give me solution if you have any idea about this error. I am not able to generate the Wdg Module properly. So please help me as soon as possible.
5 回复数
656 次查看
AmitoYao
You should modify the gpt module.
The callback of the gpt channel referred by the wdg module should  be Wdg_Cbk_GptNotification0
1,495 次查看
Shreya_Dave
Facing the same issue. Reinstalled package and tried but still getting the same error. Please help us for this
1,480 次查看
cuongnguyenphu
Let's give me information about your install environment:
- EB Tresos version
- SW package installing
- Did you have valid license for your SW package?
1,542 次查看
cuongnguyenphu
@ronakpatel84
I think this issue is because some changes in Wdg_Cfg.h makes EB Generator cannot verify this file anymore.
We faced this issues number of times and the solution is uninstall the whole package and install it again
672 次查看
zhaogang
Hi,do you have other solution? I tried uninstall and install the tresos and SDK, stll the problem exist.
