FTM2 for Modulation
FTM2 for Modulation
2,361 次查看
bjrajendra
Senior Contributor I
Hello all,
I'm trying to develop a PWM modulation with FTM2 for the S32K142 device. But it looks like the modulation doesn't work for FTM2 as per the below screenshot.
Kindly confirm the same.
RAJU
2,257 次查看
Robin_Shen
Hi BJ RAJENDRANATH,
I have check it in the latest S32K1xx MCU Family - Reference Manual (REV 12.1).
Still get the same information as the table that you found.
And I can only find the FTM0_OUTSEL and FTM3_OUTSEL bit.
Robin
2,258 次查看
Robin_Shen
Hi BJ RAJENDRANATH,
Robin
2,257 次查看
bjrajendra
Hi Robin,
Thanks for your swift response & it's really helpful.
As suggested, does it mean I can use only Channel1 alone (FTM1-CH1 & FTM2-CH1) or all FTM channels from CH0-CH7.
In other words, If I initialize FTMOPT1->FTM3_OUTSEL=0xFF; I can implement all FTM1CH0-7 signals withour initializing FTM0.
Raju.
