Do you mean in Master mode?
If so, refer to this thread:
Hi Daniel,
Thank you very much for the info.
May I know in general How to check if a microcontroller I2C supports clock stretching or not.
Can I say , if the minimum frequency is 0Hz (and/or there's no maximum time for the low period of the clock), that indicates it is clock stretching compatible.
HARI
