FS26 SBC debug hardware connections
1,467 次查看
mogilipuri_harish
hello team
we are using FS26 SBC. we need help for hardware connection for debug pin in FS26 SBC.
1,450 次查看
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
To enter in OTP Mode, the voltage on pin DEBUG must be set at VOTP (7.4V < debug pin < 8.4V) prior to apply any voltage on VSUP pin.
The debug mode can be used during customer production process. This mode can be access by applying VDBG (2.5V <Debug pin < 6V) on debug pin prior to apply any voltage to VSUP.
Therefore, I do recommend applying a circuit based on the requirements of your design. I mean, if you need both OTP and debug mode, you may place a jumper for selecting the voltage source for example. You may also include a RC filter at the DEBUG pin.
If you have an NDA number, please let me know. I can share with you further information (confidential).
I hope this information helps.
David
1,441 次查看
mogilipuri_harish
hello
this is my NDA no: 7e8f5683-eff2-42b8-8f60-0ecda241eea4
1,433 次查看
diazmarin09
Unfortunately, I am not able to validate your NDA number.
Could you please submit a new case in order to review your NDA?
Thank you for your understanding.
David
