I use S32K3-T-BOX, MCAL RTD 2.0.0 22_03, Eth_InternalLoopback example and PE micro multilink.
I added configuration for all necessary pins according to SCH-50735.pdf and disable Loopback mode. I also added a loop with a delay for cyclic Eth_transmit and flashing the U37 LED to check the run.
After Debug_FLASH everything works as expected and the T-BOX sends ethernet message cyclically, the problem occurs after turning the T-BOX off and on. LED U37 flashes to indicate software is running, but the Ethernet message is not being sent. It occurs to me that the multilink is doing some initialization that doesn't happen after the device is restarted, but I don't know how to solve this problem.
If anyone has a solution, I would appreciate any advice.
won0020
