Error when using S32K14 AutoSAR OS
3,644件の閲覧回数
geweilin
I installed tresos Studio 23.0 , Autosar OS(SW32K14-OS401-RTM-1.0.0 b4.0.98)  and Autosar MCAL(SW32K14-MCAL401-RTMC-1.0.4).
The result is that MCAL is used and tested good.
But when I try to generate OS configuration file(.c,.h), it gives the following 3 error:
1. Failed to run generator "Os_TS_T40D2M4I0R98GeneratorId" (mode: "generate") for module "Os_TS_T40D2M4I0R98"
2. Error in external generator: fatal 0201: 'S32K' target is not supported by your license!
Used generator commandline: C:\EB\tresos23\..\..\NXP\AUTOSAR\S32K_AUTOSAR_OS_4_0_98_RTM_1_0_0\os_ts\eclipse\plugins\Os_TS_T40D2M4I0R98\..\..\..\..\ssc\bin\generator\sg.exe C:\Users\weilin.ge\Desktop\os_sample_sc1\output\generated\epc\project.epc
3. The external generator for module Os_TS_T40D2M4I0R98 terminated with exit code 9
I want to what's the problem reason? and how to resolve it?
Thanks.
タグ(3)
12 返答(返信)
3,219件の閲覧回数
allenlw
the OS generator need a java run enrivonment, so you need to download a JRE from the official site and install it . I think it wil solve your problem.
3,220件の閲覧回数
qianyanhua
When I use the sample,it's OK;but when I create my project,or change the sample,it's the same error "The external generator for module Os_T40D2M4I0R98 terminated with exit code 7".
3,220件の閲覧回数
allenlw
do you install the JRE like I said before?
3,220件の閲覧回数
qianyanhua
Yes,I did it,but when I create a new project ,the error reappears.
3,220件の閲覧回数
allenlw
I don't know what exactly the problem you meet, but you can find a decimal number at the front end of the error message, then look it up at the 21.4 list of messages in the AUTOSAR_OSS32K_TR, it's a document in the OS installation folder, hope this will help you.
3,220件の閲覧回数
qianyanhua
Yes,before I install JRE, the sample generate is not OK,but after that,it's OK.Error reappears when I use a new project,or change the samle.
qianyanhua@cncaea.cn
3,220件の閲覧回数
xinxin_you
I meet this problem.How to slove it?
3,220件の閲覧回数
江洪秦
I  have the same problem. Do you know how to solve it ?
3,218件の閲覧回数
martin_kovar
I created ticket with your question for Automotive Software team. The will contact you back directly via email. Please let me know here, if you do not receive reply until end of this week.
Martin
2,560件の閲覧回数
Simin
        I also have this problem too,and don't know how to solve it,pls support me,thank you very much
simin
2,934件の閲覧回数
lubo_NEW
3,218件の閲覧回数
江洪秦
Hi, Martin,
 Could you share the solved method?
