Error "Missing Parent XML node" in EB tresos
1,228 次查看
emerging
Hello ,
When i tried to add one xdm file for MCL from nxp i am getting the error "Missing Parent XML node" as follow
Could you please check this and let me know how can i resolve this issue and how to add it in eb tresos to check the configuration.
Thanks and regards
1 回复
1,205 次查看
PetrS
check if right RTD and/or EB version is used.
Also you can try to import the epc file into the project and see the configuration.
BR, Petr
