When I was debugging with PE, I found that the S32DS would erase only after the value of an address was changed. If the APP is completely consistent, it tells me that I don't need to reprogram.
Is there a way to erase and not change the APP while debugging.
Please help, thx!
Not sure what you mean erase and not change APP. like erase only part of memory?
Or erase the whole chip via IDE? This can be achieved by programming blank binary.
Otherwise you will need to use different tools, like PEMirco IDE which offer possibility. Or different advanced debuggers which has it in IDE.
In S32DS you just cant, if the image is identical.
Peter
