Endianness of S32K144
oeren5
Hi everybody,
I am using S32K144 with MBDt v4.2. I am using CAN blocks in order to send and receive data. I want to learn what is the endianness format of CAN blocks?
Is it little endian or big endian? Also, are there any way to change this format in configuration block or the format is fixed?
Thanks in advance.
dianabatrlova
The Cortex-M has the AIRCR register where the ENDIANNESS bit is fixed as little endian for S32K1xx devices. FlexCAN register also uses a little endian and it cannot be changed.
However, I would like to suggest focusing on the "55.4.3 Message buffer structure" in RM rev 12.1
Diana
dianabatrlova
Diana
