EWM and LPO_CLK in VLPS mode
1,228 次查看
hyswx
In VLPS mode, the manual says that the EWM is disable, and the LPO_CLK of the EWM counter is Full functionality in this mode. In this case, only the EWM register is disabled or the counter is also disabled?
1,221 次查看
Senlent
Hi@hyswx
Maybe you can refer to the description in STOP mode,
In summary, I think the counter should also be disabled in VLPS mode.
1,203 次查看
hyswx
Thank you, I also want to ask what is the difference between static and OFF?
1,194 次查看
Senlent
Hi@hyswx
I don't see the relevant description in the datasheet, I can't give you a definite answer
But you can look at the appendix table in S32K-DS, maybe you can find something different.
