ECC SRAM Reporting
ECC SRAM Reporting
2,196 次查看
smt87
I am using S32K11x MCU for my project. I want to use ECC reporting for safety mechanism, so I want to learn how can i use this safety mechanism and is there any demo code or any application? I would be glad if someone explain to me.
2,182 次查看
Senlent
Hi@smt87
yes ,you can refer to AN12522
标记 (1)
5 回复数
2,189 次查看
smt87
In S32K11x on-chip RAM can be used in following applications:
• Safety critical applications: SRAM_U can be used, which starts from 2000_0000.
So S32k11xx only has SRAM_U for app, right?
2,192 次查看
Senlent
2,045 次查看
smt87
Do you have any idea how i can check this sample function working correctly?
2,187 次查看
smt87
2,183 次查看
Senlent
Hi@smt87
标记 (1)
