The error "corrupt system model" in EB Tresos typically indicates an issue with the project's configuration data, often due to inconsistencies or invalid data within the EB Tresos workspace.
The system model within EB Tresos stores information about the project's configuration, including modules, parameters, and relationships. If this data becomes corrupted or inconsistent (e.g., due to unexpected errors during saving, or manual modifications outside of the EB Tresos interface), the error can occur.
Try cleaning the project and rebuilding it. This can sometimes resolve inconsistencies in the build process.
But this is more question from EB support as the tresos is not NXP product. They will give you most accurate solution.
Peter
