Disabling data cache for memory region
2,058 次查看
nxf92571
I'm working with S32k358 uC and I'd like to disable data cache for memory region. In block diagram I see tree SRAM blocks SRAM0, SRAM1, SRAM2. Is it possible to disable data cache for SRAM2 and keep data cache for SRAM 0 and SRAM1?
Thank you,
Vladimir
1,910 次查看
StephenDu
hi,
Yes, it's easy to do this, just remove the macro: D_CACHE_ENABLE/I_CACHE_ENABLE in the related project, commonly in the project properties -> C/C++ Build -> Settings -> Tool Settings -> Standard S32DS C Compiler -> Preprocessor.
1,960 次查看
Luis_Garabo
Hi @StephenDu ,
Could you please provide an update on the progress of this support request?
Thanks in advance,
Luis
