DMA+ADC IN VLPS mode
1,255 次查看
YASHAY
can i use DMA+ADC  on S32K116 micro in VLPS mode ?
reading some documents it seems you can use but it does not give me the option on S32K Power estimation tool ?
need some guidance.
Thanks.
3 回复数
1,225 次查看
YASHAY
Thanks for the reply.
so in order to use ADC+DMA for minimum power consumption , i have to change power mode every time?
in RUN mode using only ADC and DMA what could be the typical current consumption do you have any idea ?
1,203 次查看
lukaszadrapa
Yes, ADC is not available in VLPS, so you need to change the mode. I don't know current consumption for this exact use-case, I can only recommend "Table 13. Power consumption" in the datasheet and Power Estimation Tool to get some boundaries what to expect.
Lukas
1,235 次查看
lukaszadrapa
Hi @YASHAY
you can take a look at "Table 39-4. Module operation in available power modes" in the reference manual:
https://www.nxp.com/webapp/Download?colCode=S32K1XXRM
It says that ADC is turned off in VLPS mode:
Lukas
