DEBUG as a Maser, Can command access?
1,042 次查看
1260784871
Table 15-3. MPU Logical Bus Master Assignments
MPU
Logical
Bus
Master
ID
Bus
Master
Possible access types PID
avaialable
User Supervisor Data Instruction Read Write Execute
0 Core ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓
Debugger ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓
DMA - ✓ ✓ - ✓ ✓ - -
ENET
Not implemented. The region descriptor register fields for these master IDs are Reserved.
1
2
3
4-7
1,030 次查看
danielmartynek
Can you please elaborate?
I don't understand the question.
Thank you,
1,031 次查看
danielmartynek
Thank you,
