DCF Clients parity Feature response mechanism
FabioG
in reference manual rev 8:
Par 37.2.1.1 Parity: is not clear for me in which way the  DCF client alerts MCU when detects a bad parity: "DCF alerts DCM....", but which register reports it ? does MCU software needs to test some registers in order to react to the failure, or there is a DCF Client/DCM  hardware trasparent path that manages it ?
Best Regards
Fabio
petervlna
You can find this info in reference manual:
And once DCMCERS is set it will propagate into FCCU fault:
Peter
petervlna
Peter
