Critical inconsistency with S32K144 ADC_SC1x register between CPU specification and actual value
justinsheng
There is a critical inconsistency identified between ADC specification and actual register value for ADC_SC1x.
Actual value in S32DS:
These are the register values in memory window:
CPU specification:
ADCH field has 6 bits available and setting 0x3F disables it, while 0x1F is a reserved value.
Hope NXP can clarify this issue. Which one is correct?
Tags (3)
PetrS
the register description is general across S32K1xx family. Some of the input channel options might not be available for
S32K144.
BR, Petr
