Could not inputs from TRGMUX to eMIOS by s32k3
Aren
hi
I want to input a signal from TRGMIX to eMIOS1_1.
So I set TRGMUX to the following:
TRGMUX eMIOS1_0 (eMIOS1_0) = 0x68 (LCU_0_LC3_out_i4)
But no signal is being input to eMIOS1_1.
The signal output from the LCU is fine.
The eMIOS1_1 input pin flag(UCIN) is not set either.
eMIOS is used to SAIC mode.
Please tell me the settings required to input a signal to eMIOS.
PetrS
be sure you also select TRGMUX source for eMIOS ch input using respective SIUL_IMCR register
BR, Petr
Aren
Solved! Thank you!
Aren
PetrS
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-1964153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECould%20not%20inputs%20from%20TRGMUX%20to%20eMIOS%20by%20s32k3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1964153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%3C%2FP%3E%3CP%3EI%20want%20to%20input%20a%20signal%20from%20TRGMIX%20to%20eMIOS1_1.%3C%2FP%3E%3CP%3E%3CSPAN%3ESo%20I%20set%20TRGMUX%20to%20the%20following%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ETRGMUX%20eMIOS1_0%20(eMIOS1_0)%20%3D%200x68%20(LCU_0_LC3_out_i4)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBut%20no%20signal%20is%20being%20input%20to%20eMIOS1_1.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThe%20signal%20output%20from%20the%20LCU%20is%20fine.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThe%20eMIOS1_1%20input%20pin%20flag(UCIN)%20is%20not%20set%20either.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EeMIOS%20is%20used%20to%20SAIC%20mode.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPlease%20tell%20me%20the%20settings%20required%20to%20input%20a%20signal%20to%20eMIOS.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1964382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Could%20not%20inputs%20from%20TRGMUX%20to%20eMIOS%20by%20s32k3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1964382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESolved!%20Thank%20you!%3C%2FP%3E%3CP%3EAren%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1964370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Could%20not%20inputs%20from%20TRGMUX%20to%20eMIOS%20by%20s32k3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1964370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Ebe%20sure%20you%20also%20select%20TRGMUX%20source%20for%20eMIOS%20ch%20input%20using%20respective%20SIUL_IMCR%20register%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PetrS_0-1727688067439.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PetrS_0-1727688067439.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301955iB9C59FCAC5842831%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PetrS_0-1727688067439.png%22%20alt%3D%22PetrS_0-1727688067439.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E
