Code generation malfunctions in Flexio_Pwm_Ip_Cfg.h
Gwihan
Q.1: Is there anyone having the same problem as below?
"generate/include/Flexio_Pwm_Ip_Cfg.h:54:10: fatal error: Flexio_Pwm_Ip_BOARD_InitPeripherals_PBcfg.h: No such file or directory"
I thought this message means I have done something wrong. But, this problem is easily solved if I correct header include statement manually (to Flexio_Pwm_Ip_PBcfg.h).
Q.2: What is wrong with template file (of Flexio_Pwm_Ip_Cfg.h) or my configuration?
(I have check my c-code. It will run just fine if the wrong include statement is fixed manually.)
Robin_Shen
Please try to test whether the latest S32K3 RTD 4.0.0 has fixed this issue.
Robin
Robin_Shen
Robin
Gwihan
Yes, this has fixed the issue.
Though I had to deal with few problems aroused by difference between two versions, it is worth moving onto RTD 4.0.0.
Gwihan
Is any of RTD 4.0.0 supports S32K312_172MQFP?
RTD I got supports s32k312_hdqfp172.
Robin_Shen
Yes. These two packages are actually the same, only the name was changed from MAXQFP to HDQFP.
%3CLINGO-SUB%20id%3D%22lingo-sub-1874139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECode%20generation%20malfunctions%20in%20Flexio_Pwm_Ip_Cfg.h%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1874139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EQ.1%3A%20Is%20there%20anyone%20having%20the%20same%20problem%20as%20below%3F%3C%2FP%3E%3CP%3E%22generate%2Finclude%2FFlexio_Pwm_Ip_Cfg.h%3A54%3A10%3A%20fatal%20error%3A%20Flexio_Pwm_Ip_BOARD_InitPeripherals_PBcfg.h%3A%20No%20such%20file%20or%20directory%22%3C%2FP%3E%3CP%3EI%20thought%20this%20message%20means%20I%20have%20done%20something%20wrong.%20But%2C%20this%20problem%20is%20easily%20solved%20if%20I%20correct%20header%20include%20statement%20manually%20(to%26nbsp%3BFlexio_Pwm_Ip_PBcfg.h).%3C%2FP%3E%3CP%3EQ.2%3A%20What%20is%20wrong%20with%20template%20file%20(of%20Flexio_Pwm_Ip_Cfg.h)%20or%20my%20configuration%3F%3C%2FP%3E%3CP%3E(I%20have%20check%20my%20c-code.%20It%20will%20run%20just%20fine%20if%20the%20wrong%20include%20statement%20is%20fixed%20manually.)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Gwihan_1-1716515972322.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Gwihan_1-1716515972322.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F280583iE51E1E23C8E275CC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Gwihan_1-1716515972322.png%22%20alt%3D%22Gwihan_1-1716515972322.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Gwihan_0-1716515236808.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Gwihan_0-1716515236808.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F280582i527109C82E5F34E7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Gwihan_0-1716515236808.png%22%20alt%3D%22Gwihan_0-1716515236808.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Code%20generation%20malfunctions%20in%20Flexio_Pwm_Ip_Cfg.h%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EYes%2C%20this%20has%20fixed%20the%20issue.%3CBR%20%2F%3EThough%20I%20had%20to%20deal%20with%20few%20problems%20aroused%20by%20difference%20between%20two%20versions%2C%20it%20is%20worth%20moving%20onto%20RTD%204.0.0.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1874474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Code%20generation%20malfunctions%20in%20Flexio_Pwm_Ip_Cfg.h%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1874474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes.%26nbsp%3BThese%20two%20packages%20are%20actually%20the%20same%2C%20only%20the%20name%20was%20changed%20from%20MAXQFP%20to%20HDQFP.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1874454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Code%20generation%20malfunctions%20in%20Flexio_Pwm_Ip_Cfg.h%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1874454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIs%20any%20of%20RTD%204.0.0%20supports%20S32K312_172MQFP%3F%3CBR%20%2F%3ERTD%20I%20got%20supports%20s32k312_hdqfp172.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1874323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Code%20generation%20malfunctions%20in%20Flexio_Pwm_Ip_Cfg.h%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1874323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20try%20to%20test%20whether%20the%20latest%20S32K3%20RTD%204.0.0%20has%20fixed%20this%20issue.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3ERobin%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3C%2FP%3E%0A%3CP%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
