I failed to connect to my s32k118evb board with the following information.
Is my board broken?
Bruce
My application doesn't use security or CSEc.
I tried the app downloaded from PEMicro website but with no luck.
Bruce
Have you tried the old version Kinetis_Recovery_Utility.zip attached to that post ?
Hi Bruce,
Please refer to the discussion in Can't use PEmicro debugger with S32K118EVB2-Q048
Did you enable security or CSEc?
Robin
