When I using j-link debug s32k144,it is empty in peripheral registers values and peripheral register windows.It is ok in using usb link.
Solved! Go to Solution.
Hi 郑文豪,
If you are using S32DS IDE, please try to use the EmbSys Registers window.
Robin
Hi 郑文豪,
Robin
There is no value.
Double click on register to read values, after that the register names will shown green.
Thank you !
